It is currently Sun Jul 20, 2025 8:32 pm
PostPosted: Mon Jan 22, 2007 3:35 pm
Last Name: Lloyd
Hi,
I can’t seem to stop this stuff, Supper CA, from hardening in the dispenser’s delivery tube. Therefore, I am continually trimming the tube. This creates a problem when trying to apply a small amount when filling dings and such. I’ve tried plastic wrap and tape with no success. I store it in the original double container but it still hardens. Any help would be appreciated.
Michael Lloyd
PostPosted: Mon Jan 22, 2007 4:38 pm
First name: Nelson
Last Name: Palen
Michael
One suggestion I've heard is to squeeze the air out with the container held upright just prior to applying the CA. Tilting the container back to its upright position and releasing "the squeeze" will suck the residual CA out of the delivery tube back into the bottle.
I use pipettes, as do many other folks, as disposable applicators. The above procedure will prolong the useful life of pipettes before plugging also.
Nelson
PostPosted: Mon Jan 22, 2007 9:54 pm
Thank you Nelson,
Tis little gems like you have offered just now that make-th the crown upon King OLF's head.
Long live the King
PostPosted: Tue Jan 23, 2007 2:11 am
I always screw off the top and transfer whatever I need to a pipette...and then close up the bottle. I get a lot more control and the pipette drops are of uniform size. A pipette lasts about 10 trips to the bottle for me.
PostPosted: Tue Jan 23, 2007 3:16 am
Like JJ, I always use a pipette for the low viscosity CA. Yes the tips still clog
frequently, but the little plastic pipettes are cheap and disposable so I've
never seen this to be an issue.
PostPosted: Tue Jan 23, 2007 9:30 am
Every CA I've used has had the same cloging problems until I started
useing Loctite CA
It has a patented "clog free lid" ... believe it or not, it has never cloged!
Also... you can get it anywhere.
long
PostPosted: Tue Jan 23, 2007 9:54 am
First name: Nelson
Last Name: Palen
Good information, Bob!
PostPosted: Tue Jan 23, 2007 11:47 am
Last Name: Lloyd
Thanks for the tips.
I will be using the thumb tack trick for my current bottle of CA and will be trying the pipette suggestion for the small jobs.
I see that the Loctite CA product is widely available here in Canada, so that to is on my shopping list.
Thanks again and very much appreciated.
Michael Lloyd
PostPosted: Tue Jan 23, 2007 12:12 pm
First name: Jim Howell
I've become a fan of the Loctite CA also and can report that I have not had a cap/spout clog since converting over to it. I use it in both thin and gap filling viscosities.
Jim Howell
Charlotte, NC
PostPosted: Tue Jan 23, 2007 3:26 pm
Loctite! Got it, thanks for the tip Bob!
PostPosted: Wed Jan 24, 2007 2:59 am
First name: Nelson
Last Name: Palen
I'm curious as to how many of you out there clamp the pipette bulb between your teeth for a third hand?
PostPosted: Wed Jan 24, 2007 3:45 am
Last Name: Cavanaugh
City: Saint Paul
State: MN
Acetone will dissolve hardened CA, so you can clear out your clogged tube by soaking it in acetone. I used to buy an extra tip (as Hesh suggests) and keep one tip on the bottle of CA and the other in a jar of acetone. Acetone is nasty, toxic stuff, though, and highly volatile, so I rather think the suggestion of using cheap pipettes is a better solution.
John Cavanaugh
Saint Paul, MN
"What could possibly go wrong?"
